Carb Ballancing
zxghost
My Bike: zx6r636
Carb Ballancing
Post by zxghost »
hello All,
I need to balance the Carbs on the 400 L2 model, any one know the easiest way to do this? I have a Vacum gauge tester that i can use just unsure of the easiest way to do this. Ideally want to remove as little of the bike as possible!
Thanks in advance Steve
parby81
Re: Carb Ballancing
Post by parby81 »
do a search, this has come up so many times.
But basically, fuel tank off, air box off. Put vacuum tubes on back of each cylinder (under carbs) rev to 2k rpm adjust with three screws on carbs. out side two then middle one.
Pretty sure its also in the manuals.
Re: Carb Ballancing
