hello All,
I need to balance the Carbs on the 400 L2 model, any one know the easiest way to do this? I have a Vacum gauge tester that i can use just unsure of the easiest way to do this. Ideally want to remove as little of the bike as possible!
Thanks in advance Steve
Carb Ballancing
parby81
- My Bike: ZXR400 L9
Re: Carb Ballancing
do a search, this has come up so many times.
But basically, fuel tank off, air box off. Put vacuum tubes on back of each cylinder (under carbs) rev to 2k rpm adjust with three screws on carbs. out side two then middle one.
Pretty sure its also in the manuals.
