1to2 gear problem
bato
1to2 gear problem
Post by bato »
Hi
I have problem going 1to2 gear 1000-4000 rpm and 10.000-14.000 rpm.
In the middle range rpm everything is OK but if bike runing higher than 10.000 bike going only in neutral I cank puting in the secound.I must slowing and interponse in 1 gear.
Any idea??? :smt017
Wabby
My Bike: ZXR400
Re: 1to2 gear problem
Post by Wabby »
Try doing a 'clutchless' upshift, and really pull up on that lever - See if this cures the problem.
zxr_oli
My Bike: Daytona 675
Post by zxr_oli »
Wabby wrote:Try doing a 'clutchless' upshift, and really pull up on that lever - See if this cures the problem.
It's generally not recommended to clutchless shift from 1st to 2nd since N is inbetween.
bato wrote:Hi
Any idea??? :smt017
Sounds to me like its the little ball bearing that prevents second being selected at a stand still sticking.............get in there and remove it ?
Not heard that using or not using the clutch for first to second changes :smt017 ................been banging with no clutch into second from first for years with no ill effects :smt017
bato
Post by bato »
I just heard bolls is problem.
solutions
1- Removing balls
2- When you racing shifting 1-2 gear without clutch.
That is general problem for ZXR400
bato
Post by bato »
How can I replacing balls?
On the bike or removing engine from bike?
to remove the "neutral finder" ball bearings is an engine out and split the crankcases job afaik.
you could just try moving the gearlever a bit lower so you get more of a pull on it on upshifts, I know its an occasional problem on zxr's that this sytem sticks, but i'd hardly call it common or general.
call me slow but i've just worked out what afaik means!!! :excited
zxr_oli
Post by zxr_oli »
masterofinsanity wrote:call me slow but i've just worked out what afaik means!!! :excited
:pmsl I havn't known for long, and even now i usually forget :tease
bato
Post by bato »
Hi
I try shifting 1-2 on the high rpm and dasnt going without clutch :smt018 :smt010 :smt011
I cant racing on the 1/4 mile
I think my bike is CAFE-RACER bike :pmsl
