oil leak from end of clutch cable mechanism on clutch housin
Posted: Sat May 04, 2013 10:24 am
by bootroyd
hi, i have a minor oil leak from the shaft that the clutch cable is connected to, the shaft that sits inside the clutch housing, it pivots probably 30 degrees when u pull clucth in, that part!
any ideas what it may be? is there an o ring in there that just needs replacing, thanks guys!
Re: oil leak from end of clutch cable mechanism on clutch ho
Posted: Fri May 10, 2013 7:22 am
by Andy m
Believe there is pukka oil seal tn there but also may be shaft worn inside.
confuddled
