hi, i have a minor oil leak from the shaft that the clutch cable is connected to, the shaft that sits inside the clutch housing, it pivots probably 30 degrees when u pull clucth in, that part!
any ideas what it may be? is there an o ring in there that just needs replacing, thanks guys!
oil leak from end of clutch cable mechanism on clutch housin
bootroyd
- My Bike: zxr400
Andy m
- My Bike: zxr 400 l sp
Re: oil leak from end of clutch cable mechanism on clutch ho
Believe there is pukka oil seal tn there but also may be shaft worn inside.
