revs are slow to fall when engine is warmed up
anarcht74
- My Bike: zxr400L6
I have recently changed the head gasket on my L5 after finaly getting around to taking it for a test ride i noticed the revs where very slow to fall back down when i got back. i selected neutral and revved the bike to around 4000 and it took about 4 seconds to fall then it cut out. I then tried re starting but i had to use the choke even when warm slowly let the choke off revs fell slowly again then cut out. is the air fuel mix or air leak?
- CaNsA
- My Bike: ZX6R F1
Re: revs are slow to fall when engine is warmed up
Leaky carb rubbers if i remember correctly.
Some-one will be along to confim it or to call me a lying twat shortly.
lewisdale
- CBT slow
- My Bike: zxr400 H2
yea hes right, generally either split or leaking between the rubber and the head
- CaNsA
- My Bike: ZX6R F1
- Tirpitz
- My Bike: Kawasaki ZXR400L4
CaNsA's on the money with this one. Quick way to double check is spray some easy start at the rubbers while the engine is ticking over. If it suddenly revs its bollox off that's yer leak confirmed. Easy enough fix - either seat them properly or replace if perished.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
