revs are slow to fall when engine is warmed up
anarcht74
My Bike: zxr400L6
Post by anarcht74 »
I have recently changed the head gasket on my L5 after finaly getting around to taking it for a test ride i noticed the revs where very slow to fall back down when i got back. i selected neutral and revved the bike to around 4000 and it took about 4 seconds to fall then it cut out. I then tried re starting but i had to use the choke even when warm slowly let the choke off revs fell slowly again then cut out. is the air fuel mix or air leak?
CaNsA
My Bike: ZX6R F1
Re: revs are slow to fall when engine is warmed up
Post by CaNsA »
Leaky carb rubbers if i remember correctly.
Some-one will be along to confim it or to call me a lying twat shortly.
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
yea hes right, generally either split or leaking between the rubber and the head
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
:excited :excited im not a lying twat :excited :excited
Tirpitz
My Bike: Kawasaki ZXR400L4
Post by Tirpitz »
CaNsA's on the money with this one. Quick way to double check is spray some easy start at the rubbers while the engine is ticking over. If it suddenly revs its bollox off that's yer leak confirmed. Easy enough fix - either seat them properly or replace if perished.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
