wheel base
zxr500man
wheel base
hi,just measured my wheel base,its 1358mm from centre to centre of the axels,its a good bit shorter than what the specs say it should be?i know i changed the forks but the offset difference is only 10 mm coparred to the stock ones,am i measuring it in the wrong place?
Re: wheel base
Did you give any thought to the idea that perhaps the rear axle can move? like for chain adjustment
zxr500man
Re: wheel base
the axel is pretty much in the centre of the swing arm.ya i suppose that makes sense,thanks
