Oil choices...
Posted: Wed Mar 03, 2010 8:11 pm
by Billy Wizz
Its the old chestnut, of "is it worth the extra cost" when choosing oil. Ive used standard Semi Rock oil before with great results but Ive got a tuned zxr now with RAM air etc so should I use the same (never had any probs so..) step up to the slightly more expensive Rock oil guardian, or the more expensive fully synth. This is for race use by the way?
Re: Oil choices...
Posted: Wed Mar 03, 2010 10:00 pm
by rmkd177
Rock oil every time for me..We use the Synthesis 4 racing and run our engines to 16100rpm..No engine problems whatsoever last season. We used the Guardian prior to raising the rev limit with great success,but was advised by the technical department to up it to the higher spec fully synthetic with the extra rpm we were using. Not a problem with clutch slip as some other Brands cause and on inspecting the engine ready for 2010 found no wear at all...just as a matter of course i fitted a new cam chain and on setting the valve clearances on the rebuild found only 3 that needed slight adjustment. What more can i say no dnf's...only off the top step of the podium twice (due to grid allocation) two outrite f400 lap records,three club lap records. And a £75 parts bill for the rebuild...i only change it every 3rd meeting...Cheap racing i call that...now that suggests to me that good oil is worth the money....and my money goes with Rock oil ...
Re: Oil choices...
Posted: Wed Mar 03, 2010 11:12 pm
by Billy Wizz
Mmmmm, thats what I was thinking, I guess when oil is the lifeblood of an engine then its the one thing that deserves to be the best to save a big repair bill later!!. Cheers for the advice
Re: Oil choices...
Posted: Thu Mar 04, 2010 6:11 pm
by simmo
ill agree with roger on the rock oil synthesis 4, i used it all last season in my zxr, had the enginge rebuilt over the winter, and when it was taken apart it looked brand new, and apart from having new valves due to being worn, there was nothing else wrong with it!!! even the shells looked brand new still, still had them changed tho. lol
Re: Oil choices...
Posted: Thu Mar 04, 2010 8:21 pm
by mark400
Where do you buy the stuff?
Re: Oil choices...
Posted: Thu Mar 04, 2010 10:16 pm
by rmkd177
Im sure Mark if you contact them they will give you details of their nearest distributer...very helpfull people they are.
They have a website...details maybe on there.
Re: Oil choices...
Posted: Thu Mar 04, 2010 11:05 pm
by Alan P
Re: Oil choices...
Posted: Fri Mar 05, 2010 12:29 am
by mark400
Thanks gents !
Re: Oil choices...
Posted: Fri Mar 05, 2010 1:10 pm
by Fatspanner #44
If you contact Gordon Murray on 07778 214120 and tell him that Colin Murray passed on the details then I am sure you will get a good deal.
Rock Oil have sponsored me for the last couple of years and what Gordon does not know about oil is not worth knowing!!
Re: Oil choices...
Posted: Thu Mar 11, 2010 9:15 pm
by ancozxr
Synthesis 4 racing is OK for fast street ride and track days?
I use Motul 5100 10-40 for 15.000Khm every 800kmh change.
Never see problems.
But I want to use a different oil brand.
