Vibration
ok then replace them with some same diameter steel tubing? then add bar end weights
- deviant
- My Bike: ZXR400 L3
i'd say they are almost certainly hollow, and probably surprisingly thin walled as well.RobB wrote:I hope not. They feel too heavy to be hollow anyway. They need to be solid cos a hex bolt goes through the middle to fix it to the clip-on clamp.
probably got a threaded insert welded/pressed into the other end.
- deviant
well i'll be surprised, but I am always prepared to be proved wrong!
i'm going with Deviant pn this 1 sorry RobB, get that hacksaw out!
- diesel
- My Bike: Zx7r
cool, lets see some pics!!
ps how you gonna ride your bike now you've cut the bars in half?
- diesel
- My Bike: Zx7r
- deviant
well there you go.
CarneyUK
Just incase you haven't started chopping your bike up yet
I always used to get a numb throttle hand until I had to replace my throttle cables. Once I put the new ones in they were oiled and greased up. The throttle was tonnes smoother and I didn't have to hold the throttle so hard. It made loads of difference so if your throttle is stiff or sticky then a good oil up and lube may help!! ( I wish I could have written that differently
- diesel
- My Bike: Zx7r
