Vibration
I hope not. They feel too heavy to be hollow anyway. They need to be solid cos a hex bolt goes through the middle to fix it to the clip-on clamp.
ok then replace them with some same diameter steel tubing? then add bar end weights :smt003
or as i said earlier replace with ZX6R handlebars which already have them in :smt003
deviant
Post by deviant »
RobB wrote:I hope not. They feel too heavy to be hollow anyway. They need to be solid cos a hex bolt goes through the middle to fix it to the clip-on clamp.
i'd say they are almost certainly hollow, and probably surprisingly thin walled as well.
probably got a threaded insert welded/pressed into the other end.
im pretty sure they arent, one of the bars on my ZXR is ground at the end, ill have to take a picture, in fact ive got a replacement so when i change it ill cut it in half and prove to you its solid :smt016
deviant
Post by deviant »
well i'll be surprised, but I am always prepared to be proved wrong!
i'm going with Deviant pn this 1 sorry RobB, get that hacksaw out!
diesel
My Bike: Zx7r
Post by diesel »
then im sorry to disapoint you baz but my bars are in fact solid all the way thru :)
Quicker Than Yngwie
cool, lets see some pics!!
ps how you gonna ride your bike now you've cut the bars in half? :smt003
nothing to say here, so ill leave it blank :smt004
diesel
My Bike: Zx7r
Post by diesel »
i havent chopped. i drilled them so the locating stud for the electrics could be moved and its solid. trust me. i live in wales ;)
Quicker Than Yngwie
deviant
Post by deviant »
well there you go.
CarneyUK
Post by CarneyUK »
Just incase you haven't started chopping your bike up yet :smt003
I always used to get a numb throttle hand until I had to replace my throttle cables. Once I put the new ones in they were oiled and greased up. The throttle was tonnes smoother and I didn't have to hold the throttle so hard. It made loads of difference so if your throttle is stiff or sticky then a good oil up and lube may help!! ( I wish I could have written that differently :smt003 )
diesel
My Bike: Zx7r
Post by diesel »
toad thats a good point. that was one of my ' to-do ' jobs. changing oil, filter , plugs, cables. best i get onto that. thanks for the reminder ;)
Quicker Than Yngwie
