Ram air box for flatslides?
Robbie
My Bike: zxr400
Post by Robbie »
Im having a bit of trouble getting a set of flatslides to fit with my ram air box[kit kawasaki type]the underside of the carbs [cylinder that removes to get into the jets]is hitting the ridge/bottom of the box and the carbs are still a good 15mm from seating into the rubbers.Anybody had this trouble before or got an idea to solve it???? :smt017
Ballsout Racing
Re: Ram air box for flatslides?
Post by Ballsout Racing »
Robbie wrote:Im having a bit of trouble getting a set of flatslides to fit with my ram air box[kit kawasaki type]the underside of the carbs [cylinder that removes to get into the jets]is hitting the ridge/bottom of the box and the carbs are still a good 15mm from seating into the rubbers.Anybody had this trouble before or got an idea to solve it???? :smt017
It's shouldn't be a problem, have you got the box fully pushed over the rubbers, under the lip where the large carb circlips go?
Robbie
My Bike: zxr400
Post by Robbie »
Yea box is as far as it will go over rubbers and hard against the frame on the lip for lid? :smt017
will#224
My Bike: L1 racer
Post by will#224 »
Interesting, any pictures?
I have the bottom half or a carbon airbox that is ready to used for flatsides.....
simmo
My Bike: zxr400L/vfr400nc30/er5
Post by simmo »
i use an AMS ram air box with my flatslides.........
It is possible to have a ram air box that is designed for use with CV carbs...........and flatside will not fit with this type of box..............I know I've got one and the flatsides foul rather badly and will NOT fit.
In the case of my box it is the cable bracket on the flatsides that causes the problem...............that and the box not being able to accomidate it
The solution is to get yourself a box designed to fit flatsides
gaz9176
My Bike: triumph speed triple
Post by gaz9176 »
yea iv had a similar problem with the return cable bracket, we dont use this anyway so just cut it off.. as for float bowl mine was just hitting on the tube to the idle jet, very long tube really so just filed it down on an angle till I got what I wanted. hope this helps.
Ballsout Racing
This has reminded me of a problem, same as above, the return cable bracket fouled the box, as I/we only used the pull cable, the bracket was bent out of the way. I've got the BBplastics box for CV carbs, and the flatslides go straight in with just bending the bracket as above. The bigger problem is if you buy a box for Flatslides then try to fit CV's, the 'butterfly adjusters' hit the box when opening the throttle as I found out :smt013
