Gravity Problems
Miles
My Bike: ZXR 400 L3
Gravity Problems
Post by Miles »
Took the bike for a spin the other night and noticed something odd. When the bike goes up hill it bogs down and will only rev to 1k but when it goes down hill it rev's by it's self to 13-14k?
Could this be a float bowl problem as this is all I can think is moving?. I cleaned the bowl filter's when I was re-building the bike could I have up-set the needle's?
Mad Phil
My Bike: Hayabusa, Ducati 996SPS
Re: Gravity Problems
Post by Mad Phil »
It revs to 1K ?? :smt017
The tickover must be 1250rpm ish. So it revs to below tickover ? :pmsl
Do you mean 10K...?
Is it restricted to 33bhp?
you can check the float levels by putting a long, clear piece of pipe on the carb drain outlets and opening the drain screw. Then route the pipe to just beside the RHS of the carbs and theres a line marking on there telling you where the fuel should be.
Miles
My Bike: ZXR 400 L3
Post by Miles »
No I mean 1k she bogs to below tick over and will cut out if i dont hold the throttle fully open.
She is un-restricted
Vard66
Post by Vard66 »
Is the idle speed really that high?
I've been setting mine to about 850ish, it's no wonder it feels pretty lumpy at that.
Vard.
_________________
1997 Volvo 850 R
tickover should be at 1250rpm. Probably find your getting quitre a bit of engine braking too id imagine lol Might be why you have a problem starting it vard?
Vard66
Post by Vard66 »
It can't help, certainly!
Vard.
_________________
1997 Volvo 850 R
