(Engine swap) why did i do it?
diesel
My Bike: Zx7r
Re: (Engine swap) why did i do it?
Post by diesel »
masterofinsanity wrote:tbh i think there's only 3 wires that were messed with, alternator, starter & pickup wires, i aint got any loose ones anyway lol.
you will have a few loose ones if you cant fix this lol.
Quicker Than Yngwie
MillaMeter
Post by MillaMeter »
Hi,
I would say use the short springs they look to be the OE kwak ones. Give the carbs a balance maybe? Check for needle wear? perished diaphams? blocked starter jet? check mixture screws and o-rings for wear. Check float heights are at the right height. Oh and don't forget the float needle valves ;)
There's a couple of things to check if you haven't already done it.
Regards
Rich
MillaMeter wrote:Hi,
Regards
Rich
i would mate but i am using my original carbs which are running perfectly.
spent all weekend pissing about with the zxr and balanced the carbs god knows how many times, i am seriously losing patience with it, anyone any suggestions as to why its revving and hanging?
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
thinking about it mate, if the carbs are fine then theres only really one more thing it could be, air leak, would have a look again if i was you mate,
also did you ever see or hear this engine running before you got it?
no but from reliable sources i have been told its mint. i have checked again on saturday for air leaks, spraying carb cleaner all around the carbs whilst it was running which made no effect whatsoever.definitely sounds like an air leak, could the head be cracked?
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
i suppose its possible, spraying carb cleaner whilst running is ok, but you cant get to the underneath of the rubbers can you, also mate is all youre airbox complete and together properly?
i had the airbox off when i sprayed all around so i could get in underneath as well, made no difference to the revs at all, bike was running spot on until i swapped the engines, all i have done is taken one engine out and put another one in.
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
dunno then mate, change the plugs and do a pressure test on the engine, that way at least you can rule out any engine problems, have you checked the timing?
i was wondering wether the timing would cause these problems meself???
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
well i supppose it could, its worth checking, then at least its one more thing off the list, what about pick up coil? may be worth trying the one off youre old engine
tbh mate i don't wanna start awapping from one to the other, the only reason i bought the new engine was cos i dont have the time to do the valves and chain on the old one, how wrong was i?? think i'm gonna just do them on the old engine now and put it back in
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
yer i spose mate but surely if one of these silly little things works its easier than doin the valves and chain on the old one and refitting?
or i could cut my losses and sell the lot lol
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
lol mate i know how u feel, my 400 has been giving me problem after problem as soon as one things fixed then something else goes, pisses me of big time, nearly took a hammer to it the other day, lol
Locked
