SP CDI and Loom
SP CDI and Loom
Need help here - having layed out for the above and installed it on the bike it seems I hadnt done my homework!!! Is it the case that the SP CDI (or the F3 for that matter) wont run on a standard bike without mods to the pickup/ rotor? - that would explain why bike turns over but no sparks!!! Toad :smt013
Any suggestions??
Any suggestions??
Re: SP CDI and Loom
you need a SP ignition rotor
Re: SP CDI and Loom
thanks for that - am I right in assuming that these are like rocking horse toad or is there an after market supplier?
Re: SP CDI and Loom
i'm sure these are a resonably priced item from cradley kawasaki.
- coley
- My Bike: zxr400 racebike
Re: SP CDI and Loom
Agree with Cargo about the rotor, but I think even with the wrong rotor you would get a spark, just at the wrong time. cheers, ben
Re: SP CDI and Loom
The loom has a couplw of resistors in place - am going to try changing them for a new 100ohm to see if that helps as the wrong rotor should give me some sparks but nothing so far. I know that the ognition lock out resistor is 100ohm so will try that when i get a chance.
thanks for the steer towards Cradley - will give them a call tomorrow. I am hoping that the SP CDI is worth the hassle!!
thanks
thanks
- My Bike: zxr 400 racebike
Re: SP CDI and Loom
i got an ignitech cdi and had the same problem. just needed to upload the zxr file to the unit and away it went. then i could adjust all the settings to what i needed. also has shift light and kill box for a quickshifter. if you need a rotor ignitech will make you one to your spec for 4 euros yes four. check out their site.
Re: SP CDI and Loom
zxdillan wrote:i got an ignitech cdi and had the same problem. just needed to upload the zxr file to the unit and away it went. then i could adjust all the settings to what i needed. also has shift light and kill box for a quickshifter. if you need a rotor ignitech will make you one to your spec for 4 euros yes four. check out their site.
The CDI is a kawa unit and is not programmable (as far as I know) as it doesnt have a progamming interface - or am I being stupid!!
Re: SP CDI and Loom
Cost of new rotor from Cradleys - £225 !!!
Anyone got one that I can borrow to get copied or - anyone got dimensions to get a pattern one made??
Dave
Dave
Re: SP CDI and Loom
SWEET BABY JESUS!! £225!!
try ams motor sport, they're zxr400 breakers. 01758730522 or 07798714703.
Re: SP CDI and Loom
I'm calling Cradley again tomorrow - I cant believe the quote today. It must cost about £20 max to make this rotor - maybe they priced it with a new crankshaft!!!!!!!
trid Brian at AMS - he is having a look to see what he has got in stock
thanks for all help
thanks for all help
Re: SP CDI and Loom
Good news - when they prcied the rotor yesterday the tech priced the "flywheel rotor" - the ignition rotor (what i asked for) is £35
Bad news - it is no longer stocked
However - the SP rotor number is 21007-1223 so I am on the case with other suppliers - good fun!!!!!!
Re: SP CDI and Loom
To be honest I don't think Cradley would have ever stock a SP ignition rotor.
If your struggling to find one get back to me I suspect there's one lurking in my workshop somewhere............................
Re: SP CDI and Loom
Thanks mate - I think I have sourced one but am not celebrating till it arrives. Thanks for the offer - will come back to you if this turns out to be a dead endcargo wrote:To be honest I don't think Cradley would have ever stock a SP ignition rotor.
