iv got a race exhaust for MOT. HELP!
Head-Down
My Bike: ZXR400 L1
Post by Head-Down »
i have my bike MOT on friday at wheel -fit motorcycles, and i have just relised the full system that i have says not for road use on the underside of the tip. would it make any difference if i filed off the "not for road use" or do i have to get a standard exhaust.
Ride hard or die Tryin'
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
I THINK they would still fail it on the basis of being open. Get a DB killer on ebay for the MOT then remove it.
Andy
deviant
Post by deviant »
if it says "not for road use", it will fail an MOT
otherwise, it's down to the testers discretion, so you never know till you try.
ratbag56
My Bike: zxr400 / 636
Post by ratbag56 »
i polished mine off my micron end can (i hav the full system) and it went straght throu! they dont test emissions only noise and road use labels
new mot laws state if the exhaust is louder then factory fitted std oem items it will fail wether it say for road use or not for road use.
deviant
Post by deviant »
however the tester, having no access either to a noise meter or an identical bike with standard can...will use his discretion.
gubbs
My Bike: ZZR1100C3
Post by gubbs »
ratbag56 wrote:i polished mine off my micron end can (i hav the full system) and it went straght throu! they dont test emissions only noise and road use labels
... is the right answer. :)
I've got a strate though Avvy system on my ZXR750 what makes car alarms go off a ears bleed...its got "NOT FOR ROAD USE" and "RACE USE ONLY" writen all over and the mot tester ask if i've got the standard pipe to what i said yes and its sailed though
If it failes and not declaired unsafe to ride then you get 10 days to fix the problems they failed it on if that happens i've got a spare standard can for the 400 in my shed
I went to the place beforehand and asked if the can was ok.
They said "I can't hear it." He called to the other mechanic "Can you here it?"
"No." came the reply.
So they said it would be fine.
Never mind the fact that the bike was switched off while I was inside asking! :smt003
It's their discretion, and most will be ok about it.... UNLESS it has 'Not for road use' - in which case they can't pass it.
Jamz wrote:UNLESS it has 'Not for road use' - in which case they can't pass it.
like i said mine HAS got this on it and its passed every time.
I think it just deepens on who's testing it and weather the Mrs hasent put out for the last 3 days or not..
Also a MOT tester cannot remove anything from the bike so your alowed to stick tape over things (e.g. the NOT FOR ROAD USE SIGHN) and there not alowed to look under it :smt002
i also heard that if u polish off the 'NOT' in 'not for road use' then if the old bill pull you over, not only is your bike ...
* not fit for road use
u r also
* perverting the course of justice - not good!
your only perverting the course of justice if they can prove you are :smt002
Like its only illegal if you get caught :smt003
gubbs
My Bike: ZZR1100C3
Post by gubbs »
Gemini wrote:i also heard that if u polish off the 'NOT' in 'not for road use' then if the old bill pull you over, not only is your bike ...
u r also
A couple of years ago I would have pissed myself laughing at that statement.
Now its just another 'Detection' off the list for this month. ;)
my yoshimura can is a race can im sure, but it dont have any mention of it bein a race only can or not for road use.
so i guess im ok? although i do know the mot tester and if worse comes to worst ive got the original can
the police are really lax on these things now, it was in a few mags saying that the police no longer bother with doing you for number plates, inted visors or race cans just not worth there time. Unless of course your being a dick and they want a reason to pull you
from personal experiance i've got all 3 and havent been done for it in the last 3 years i've been rideing
