Hi folks,
Hope this is the right part of the forum - I'm a newbie here. I took delivery of my 400 yesterday - it's a L 1992 model, 20000 miles and in really good nick and running order. The only issue I can see (apart from the carbs needing setting properly) at the moment is a poor join in the seat farings - they don't join in the middle that well and the previous owner solved it with some black tape which looks nasty. I'm new to this bike so sorry if this is a stupid question but what, if anything, is usually used on this join? Cheers in advance for any advice! Jez
Seat fairing fitting on an L2
Re: Seat fairing fitting on an L2
they should join mate, take both seat pads off, there should be 3 screws keeping them together, if they won't join then the subframe may be bent?
Jez
- My Bike: ZXR400
Thanks for quick reply, I'll have to investigate it later - hope it just some missing screws or broken lugs and not the subframe! Cheers, Jez
will#224
- My Bike: L1 racer
If its just the rear section of the subframe thats twisted i have one here, make me an offer.
rover220
- My Bike: zx7r p6
undo all the bolts holding the panels onto the frame then join the two halves together. try and refit and if the holes wont line up then the frame is bent.
Jez
- My Bike: ZXR400
Cheers guys, I will try that later. Will, I will let you know if it is the subframe and make an offer if I need it. Thanks again, Jez
there should be 2 bolts holding the plastics underneath the rear seat pad, these are probably missing too. or have rusted in, heads snapped off and the plastics are catching on the broken stubs which is why there may be a gap.
anyone considered they might be cheap plastics?
Jez
- My Bike: ZXR400
Thanks guys - I'll have a look at the bolts as well. You could be right as well Redex, they might be replacement plastics although they are ij the right colours. If they are nastys can anyone recommend a good make for replacements (I'm not going for anything on ebay from China - they all look well dodgy). Cheers. Jez
there's usually loads on ebay, i've got some green ones.
