Well this weekend I have plans of finishing putting the rest of my zxr back together and finally start her up after nearly a year of not starting her.
I plan on cleaning the carbs whilst it's running as I have a portable fuel tank so I have full access to the carbs.
I just hope she starts and runs ok as she has had a lot of time and new parts spent on her (still more to buy)
Will let you all know how I get on
Busy weekend
tink
- My Bike: ZXR400 L2
Re: Busy weekend
Doing much the same - good luck with the start up
Re: Busy weekend
good luck
tink
Re: Busy weekend
Well it's started and sounds sweet but the only problem is I have no front lights dipped or main beams, can't find any thing wrong
Re: Busy weekend
Fusebox or fuse
Re: Busy weekend
Checked the headlight relay?
tink
Re: Busy weekend
It doesn't have a headlight relay as it's a jap import. All fuses are ok but not power going to the light bulbs
tink
Re: Busy weekend
This is it running but no air box or fuel tank fitted
Re: Busy weekend
Do you have another fusebox to try - they can fail as well as the fuses.
Test it for continuity to make sure power is getting in and back out.
