put it back together wont start
tomzxr400
Post by tomzxr400 »
just want to check ive connected these right does this pipe Image go onto the carbs here in red then the yellow pipe go onto the head near the thermostatImage
the head was tottaly cleaned and the carbs were to the bike turns over and sparks but wont fire up is there any tricks to get the oil/petrol flowing to fill the carbs and cams with oil/petrol any advice cheers guys
that all looks about right to me, if the carbs were dry when you put them back on they take quite a while before the fuel pump fills them back up again. I found this out only the other week when i flattened my battery twice before the carbs were full of fuel and actually fired up.
