Engine Overhaul
jonb_5
My Bike: ZXR400 H1
Engine Overhaul
Post by jonb_5 »
I have the engine out of the bike at the moment and am going to make sure its in tip top condition.
What should i be doing?
I am guessing valve clearances, how do i do i check these and how would i replace the shim?
Also plugs, oil, filters etc.
What else do i need?
Jon
Re: Engine Overhaul
Cam chain and tensioner blades are worth doing. Id do the head gasket too while i was at it.
A guide on the shims is here
viewtopic.php?f=55&t=8002
New plugs oil and filter are a good idea :)
Re: Engine Overhaul
If you want your engine like brand new again then I'd have new mains and big end bearing shells in it too.
Replace the seals on output shatt and gear change
Close inspection iof the gearbox and gear change particulary selector forks
Get the valve seats at least lapped in if not recut
