Cooling system overview
Image Image
H & L model specifications the same
Coolant:
Type : Permanent type of antifreeze for aluminum engines and radiators
Color : Green
Mixed ratio : Soft water 50%, coolant 50%
Freezing point : -35°C ( -31°F)
Total amount : 2.3 L (reservoir tank full level)
Radiator:
Cap relief pressure : 93 -123 kPa (0.95 -1 .25 kg/cm2, 14 -18 psi)
Thermostat:
Valve opening temperature : 80.0 -84.0°C (176 -183°F)
Valve full opening lift : Not less than 6 mm @95°C (203°F)
