Gear Oil
- Miles
- My Bike: ZXR 400 L3
Gear Oil
This maybe a stupid question but I take it there isn't separate gear oil and the zxr uses the engine oil to do both. Just thinking as I never changed it if there's is and it might be filled with water. (there was 3 liters of water in the sump)
Re: Gear Oil
lol no engine and gear oil is altogether.
- extonyg
- My Bike: zxr 400 L1 uk
Re: Gear Oil
ye its the same,
3 litres of water in the sump??thats not good are you sure it was water
- Miles
Re: Gear Oil
lol yes it was water. My ZXR was completly submerged. Had to borrow a friends JCB to get it out. Removed the sump and it just started pissing water. Eventually oil came out.
- extonyg
Re: Gear Oil
o dear that doesnt sound good.hopefully as long as you get all the water out it should be ok.
fingers crossed
fingers crossed
Re: Gear Oil
thats not going to be good...hydro lock!
- Miles
Re: Gear Oil
Luckly when I knew i wasn't going to make the left hander and i saw i was heading for barb wire and quite alot of water i hit the kill switch so the engine would have just filled with the water as opposied to 'sucking' it in.
