Brake light switch won't work
Jeppo
Post by Jeppo »
Got a new brake light switch off a zx7-r which im pretty sure is identical. Tried to hook it up and nothing....light not working. Any way to test if the switch works? Or if the other half of the circuit is working? I went down pretty hard and it ripped the switch straight off the bike so the contacts are a little crooked, but surely as long as they touch then it should work?
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: Brake light switch won't work
Post by lewisdale »
have you checked the bulb? you dropping the bike could have broken the filiment inside
disconnect the wiring from the switch there is 2 terminals, bridge em with a paperclip or something metal and the light should come on, if it does your switch is buggered.
Jeppo
Post by Jeppo »
Its not the bulb as the front works. Cheers baz i'll give that a try when i get home.
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
lol the front will still work if the bk dont
lewisdale wrote:lol the front will still work if the bk dont
:ffs
He means that the front brake still illuminates the bulb therefore the bulb is not broken,.................................
zxr_oli
My Bike: Daytona 675
Post by zxr_oli »
It's not the most complicated circuit in the world... Just trace the wires to find the fault.
