recomended engine builders?
- Dazzle
 - My Bike: Kawasaki ZXR400 L3
Hello can anyone recommend someone that can rebuild my engine basicly the head gaskets gone and i'd like the rings changing along with valves setting etc. i can take the engine out myself and take it somewhere thats not a problem just haven't got time to build it. Cheers Daz
- Dazzle
Re: recomended engine builders?
someone a bit nearer to home lol your in ireland
						- jake
where are you daz?
						- Dazzle
i'm in lincolnshire but don't mind travelling. Thinking about doing the build myself now the only things i need to know really are do the barrels have individual seals at the bttom or just the gasket? and what do you do about rings oversized etc? do you just measure the bore? hanks Daz
You would only need over sized rings if you had the barrel rebored to match and you'd need over sized pistons as well
				Jeppo
A bloke called graeme france in brigg is a very good bloke. Builds race bikes but i'm sure he would be happy to rebuild your engine....
						- Dazzle
Ok thanks where would i get these pistons and rings from and how much am i looking at roughly? is there anything else i should consider whilst rebuilding? Thanks Daz
Pistons and rings are a Kawasaki only part so you need a Kawasaki dealer
Best is Cradley Kawasaki
http://www.cradleykawasaki.co.uk/
Don't forget you will also need to have your barrels machined given the cost involved it might be cheaper to buy a good second hand barrel
And to be honest you would only need to do this at all if you bores are badly worn...................what sort of mileage is on the bike.
What makes you believe you need to do this
- Dazzle
The bikes done 20k i'm just asking for advice really as i've only worked on car engines. so if the bores are ok what do you suggest just new rings? i presume theres a tolerance measurment for the bores in the manual? i may strip it down myself yet as it doesn't look complicated
