carb cleaninghi
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
carb cleaninghi
Post by lewisdale »
just stripped my carbs down and they were quite shitty inside, i noticed when i took the float bowls off that one of the end floats was sitting a lot lower than the rest, i take it this is probably the cause of my bike running crap, how do i adjust/set the float heights? another thing is, there are little rubber seals on the float need le housing, like o rings, do i have to order new ones or will ones out of a general o ring box set do the job? as mine are split, cheers guys
Re: carb cleaninghi
if your o-rings are split then yes it will run crap, as will your float height, i think you just bend the little tab under the floats to change the height.
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: carb cleaninghi
Post by lewisdale »
ok mate how do i get the heights right then?
Re: carb cleaninghi
check the manual i think its 11mm from memory, hang the carbs up and measure the floats, best look in the manual cos it shows a clear pic of how to measure them
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: carb cleaninghi
Post by lewisdale »
ok mate thamks, will do, do you know if the o rings have to be ordered or if normal ones will fit?
Re: carb cleaninghi
for the price of them i would get the right ones from cradley.
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: carb cleaninghi
Post by lewisdale »
ok thanks, juat another quickie, my carbs have 102 jets, would the mixture still be right if i done it as standard?
Re: carb cleaninghi
don't talk to me about jets mate i aint got a clue, sorry!
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: carb cleaninghi
Post by lewisdale »
gunna sound really thick now but dont understand the manual, am i right in thinking i have to tilt the carbs so the tang just about touches the needle and then measure from the part of the carb where the chamber bolts on, to the top of the float? or do i just lay the carbs upside down and do it?
Re: carb cleaninghi
think you were right the first time
diesel
My Bike: Zx7r
Re: carb cleaninghi
Post by diesel »
first time is right.
Quicker Than Yngwie
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: carb cleaninghi
Post by lewisdale »
ok thanks, so now just the one more thing i need to know lol, as my carbs have had 102 jets put in, which i understand are slightly bigger than standard, would i still use the same 2 1/4 turns on the mixture? or would it be different?
diesel
My Bike: Zx7r
Re: carb cleaninghi
Post by diesel »
id stick to the original settings as a base point. then see how the bike runs from there.
Quicker Than Yngwie
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: carb cleaninghi
Post by lewisdale »
ok , if i doesnt run well will i need to loosen the mixture screws more of tighten then?
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: carb cleaninghi
Post by lewisdale »
HI JUST SETTING MY FLOAT HEIGHTS, TWO WERE AT 16 MM AND THE OTHER TWO WERE 10ISH, NOW THE SETTING IS 12 BUT THERE IS A 2 MM TOLERANCE EITHER WAY ISNT THERE? JUST TO CONFIRM, SO THEY DONT ALL HAVE TO BE BANG ON, FOR INSTANCE I COULD HAVE ONE AT 10MM AND ONE AT 14? OBVIOUSLY IM GOING TO GET THEM AS CLOSE AS POSSIBLE BUT JUST WANTED TO MAKE SURE THEY HAVENT GOT TO BE BANG ON? CHEERS
