putting barrells back on
toykaboy
Post by toykaboy »
as the topic suggests, haveing a spot or trouble putting them back on.
now i havent taken the bottom end off what i had done is strip the engine (except split the crank cases) to sort a knocking noise, but after all the checking i cannot find anything abviousley wrong.
i took the pistons off now i cant get em back in the barrells, jus wondering if any of you guys have had the same problem, and the ways you got round it?
cheers rob
you bend it you buy it!
use 2 lengths of wood underneath the pistons to keep them up straight, drop the barrels on then remove the wood :smt003
