kit ignition
zxdillan
My Bike: zxr 400 racebike
kit ignition
Post by zxdillan »
hi, just got a kit ecu from ebay. has any one had any experience in setting one up or any other maps which would work well. thanks.
Re: kit ignition
depends what you mean by "kit ignition" really .. and H or L ?
im guessing its an F3 spec SP unit.
i should have some maps in a couple of weeks once my programmable units have arrived and been setup, but i thought the SP ignitions were non-programmable without delving inside them ?
TK400 knows more than I though.
Re: kit ignition
just looked on ebay ..
if you are milliemuppet and bought item 360091652731 its the same as I'm getting so yes, i'll have some data for you.
I can also supply the units for £90 + postage.
vince67
My Bike: ZXR400 L1
Re: kit ignition
Post by vince67 »
hi :-D ,
it's an Ignitech box, the manufacturer: http://www.ignitech.cz/english/aindex.htm
I have this ignition box on a RGV and I would like to plug it on my ZXR, zimm, could you send me too your file?
thanks ;-) ,
Vince
will#224
My Bike: L1 racer
Re: kit ignition
Post by will#224 »
Are these the units we were talking about a while back? From Europe?
Re: kit ignition
yeh they are the ignitech ones,
I've got 5 turning up this week, all spoken for though, but will be placing another order shortly.
you can always order direct from them, but im getting a slightly reduced price due to bulk purchases.
Re: kit ignition
vince67 wrote:hi :-D ,
thanks ;-) ,
Vince
email ignitech, im assuming they will be able to send you a base settings map to use your tcip4 on a zxr, then its just a case of getting the wiring right.
I'll be posting my experience with these boxes as well as maps once they are fitted and setup.
Re: kit ignition
pm me with your email address and i'll send my map over.
loosely based on the f3 kit advance curve, my bike runs with it, but has NOT been dynoed.. or even ridden.
im not entirely sure the base advance is correct.. or that the pickup/coil settings are 100%
tk400
My Bike: ZXR400 , ZXR950
Re: kit ignition
Post by tk400 »
I will get those maps completed for you soon zimm. has the unit you have got 4 coil channels or only 2. Also have you programmed the dwell in at all. My guess is 5ms on the dwell static throughout the rev range as a start. but I can provide a beter idea of a dwell map soon. has it got any auxilary outputs at all that are 3d mapped. cheers
regards TK400
Re: kit ignition
tk400 wrote:I will get those maps completed for you soon zimm. has the unit you have got 4 coil channels or only 2. Also have you programmed the dwell in at all. My guess is 5ms on the dwell static throughout the rev range as a start. but I can provide a beter idea of a dwell map soon. has it got any auxilary outputs at all that are 3d mapped. cheers
regards TK400
they are 2 channel units, 4 channel are available, but i dont have one (yet)
dwell being the duration of the signal to the coil ? if so, i have two settings to choose from, 3 or 6ms, using 3.. more reading required to see what the coils actually need.
it can utilise a TPS to provide 100 points on the ignition map, also can control an exhaust valve (YPVS/EXUP)..
also, outputs for a shift light.. n stuff .. grab the software from ignitech and have a look, will run with no unit to talk to.. probably the easiest way to see whats available.
im thinking a 4 channel unit would be ace with those stick coil badgers :)
tk400
Re: kit ignition
Post by tk400 »
I like the sound of the 4 channel...what could you get one of those for in Aussie dollars...As for the dwell...go with 3ms as the worst that can then happen is a non saturated coil which will lower the spark intensity but probably not effect the maximum ionization voltage. hence the coil will still ignite fuel at higher combustion pressures. where as if you go with six you run the risk of burning out the coils and overloading your CDI. does the CDI have a maximum voltage clamp and current control. As some do and this changes the calculation for dwell time ( yes dwell is the length of time for which the coil is charging). in any case I don't think it will actually be able to sustain a 6ms dwell at high revs as the window is to small.
16,000rpm = 267 r/sec
period = 3.75ms
therefore if you include the discharge time and give the coil a slight rest you only have 2.5ms or so available. So i wonder what it does when set at 6ms at high revs. This is why waste spark systems SUCK....lol.
anyway ill get some data up soon. sounds good zimm, maybe I could do some map develoment work for you in exchange for a 4 channell!!!!! :excited :excited :excited :smt002 :smt002 ...lol.
cheers mate
kind regards TK400
Re: kit ignition
the longer dwell time is there because the units are quite popular with the classics crowd, british bikes and ducati's and stuff ... twins that rev to 7000.
your explanation is similar to the badly translated czech that came with them .. so its all starting to make sense this end... lol
yeh, startng to understand why wasted spark systems suck ..
4 channel all singing all dancing unit would be around 370 AUD, or about 250 AUD for a 4 channel version of the units already purchased. (plus shipping)
tk400
Re: kit ignition
Post by tk400 »
if the unit has a heatsink on it of sorts...you could always monitor the temp of that and the temp of the coils over 10 laps and see where your at...just use a thermocouple hooked up to a multimeter..they are cheap and most multimeters now have a k type thermocouple input..
sounds good anyway zimm, cant wait to test those CDI's and compile all the data. I may put it all on a website and get master to put a link to it as there is a fair bit of data so far. but I will get waht I can through to you soon. Just been busy gettin my bike back together for the summer. Its good riding weather over hear and I want in on it.....the mountains await for the Howl of the FCR's......LOL....
cheers
regards TK400
leon#51
Re: kit ignition
Post by leon#51 »
Has anyone seen the programable cdis for sale on ebay at the moment? Has anyone had any experience with them?
Ballsout Racing
Re: kit ignition
Post by Ballsout Racing »
Any updates on these ignitions?
