hints/tips for head gasket change
leezzr600
My Bike: '02 ZX-9R, '10 Sprint ST
Post by leezzr600 »
Hi everyone :smt001
I'm in the middle of getting my hands on a non runner '91 L1 zxr400 as my ladies first "big" bike , it needs a head gasket change, and some TLC and as it looks a bit shabby :smt010 . I'm fairly happy with doing the job and have got my hands on the manual/service guide. I'd like to know from anyone out there who has done a HG change of anything to look out for or things that make life easier when doing it, it looks fairly straight forward to me at the minute, also with the lump apart is there anything else worth changing and/or looking at (the bike has done 33,000 miles)
and , if I need to lower the bike a bit to accommodate the missus's petite frame ,whats the best way of doing this?
Any info would be great :smt003
Lee
Re: hints/tips for head gasket change
Hi Lee
might be worth checking the cam chain and valve clearances, as for the ride height try taking some foam out of the seat, been done b4.
add a bracket between the top mounts of the frame and subframe to pivot the whole thing down a bit .. or re-drill the lower mounts .. same effect ..
how short is she though? my mrs is 5'3" and can ride both H and L models as well as her zx4 absolutely fine.
leezzr600
Post by leezzr600 »
mine missus just scrapes over 5" bless her!! she has sat on one before, and i think she was ok, but i can't remember what model it was? are they different?
so cam chain , and valve clearances should do it , thanks for the info guys :smt001
H models are a bit higher with a longer stretch to the bars, there's not much in it tbh.
diesel
My Bike: Zx7r
Post by diesel »
i kow it sounds weird but its easy enough to drop the engine and do it on a bench. ive done the HG , many times lol, in-situ, but this time i did the base gasket as well. piece of piss. just take your time, be methodical and get a GOOD torque wrench.
Quicker Than Yngwie
leezzr600
Post by leezzr600 »
would recommend doing the base gasket at the same time as well then?
ive always done the base gasket at the same time as the headgasket
leezzr600
Post by leezzr600 »
i'm sure one more gasket change can't hurt!
leezzr600
Post by leezzr600 »
are the stretch bolts a one use only thing, or are they ok provided they haven't stretched past a certain length??? :smt017
diesel
My Bike: Zx7r
Post by diesel »
zimm wrote:ive always done the base gasket at the same time as the headgasket
yea it just makes sense while you are that far dismantled. rules out any base gasket probs too.
Quicker Than Yngwie
i've reused the bolts countless times.. they'll be fine.. i dont think they are "stretch" bolts per se anyway .. the torque for them is actually REALLY low
diesel : yeh ... plus i always bin it and use sealant.. tightens squish quite safely by .2mm :)
diesel
My Bike: Zx7r
Post by diesel »
zimm wrote:i've reused the bolts countless times.. they'll be fine.. i dont think they are "stretch" bolts per se anyway .. the torque for them is actually REALLY low
higher comp, more hp? ;)
Quicker Than Yngwie
leezzr600
Post by leezzr600 »
i think these little beasts are quick enough aren't they? :smt004
leezzr600 wrote:i think these little beasts are quick enough aren't they? :smt004
NEEED .. MORE ... POWER .... :excited
diesel : yeh, its not a lot but it helps.. its all ive done with mine really apart from pipe/jets and air filter** and it was making 66bhp @ the wheel which isnt loads, but stock would be anywhere from 55 to 60. add in a properly skimmed head, needles, matched inlets and stuff and 70's meant to be quite easy to get
**the ignition mods i made are actually costing me about 2 bhp at the top but its worth it for the throttle response.
