Does any body know what chain size is for a 91 L Model. Its for track bike.
Chain Size
DanP88
- My Bike: ZXR400L (Race Bike)
will#224
- My Bike: L1 racer
Re: Chain Size
520 pitch, the length depends on the sprockets your using count the links you've got on there now if your keeping the current sprocket sizes
Re: Chain Size
any decent 520 chain, cant remember the number of links, but its either 108 or 110 depending on wether its an H or an L
i normally end up buying whatever 520 chain i can get my hands on and cutting them down to the length i need
DID520ERS chains are cool .. as long as you remember to lube them before each session.
will#224
- My Bike: L1 racer
Re: Chain Size
Ive always run non 'o' ring on my race bikes and the two new bikes are the same. Just replace half way through the season.
Re: Chain Size
110 links for an L model.
jamkwak
- My Bike: ZXR400L EX WORKS KAWASAKI
Re: Chain Size
Will.... Why non O ring, any particular reason... ?
Re: Chain Size
because the weight of the chain is like half, and the friction non-existent
seriously, on a low powered bike, its actually noticeable.
just lube before each event and its fine
- robracer
- My Bike: ZXR 400SP L1
Re: Chain Size
On the race bike I run an RK 520 H ring on an alloy rear sprocket & std front sprocket, I pick the H ring as they are cheaper & I usually replace the race bike chains every 2 seasons anyway......+ the H ring seems to be more flexible than the O ring when handling the new chains.
1980-Z1100 road racing sidecar swinger 1980-Z500 race bike
2005-Z750 roadie somewhat modified 1991 - ZXR400SP race bike
