carb balancing pipes
question for ya's technically knowledged peoples.
regards the balancing pipes on the carbs, now there is usually 2 sets of pipes connecting pairs of carbs or the inlets are blocked off with rubber caps.
if one of the pipes comes disconnected or one of the caps is missing leaving the inlet stub exposed, is this likely to cause running problems?
Re: carb balancing pipes
yes, as the cylinders with the missing pipe/open nipple will be running lean, and with an uncontrolled unpredictable mixture at that because the air is entering downstream of the carbs.
so thats why my bikes running toad then? so i reckon one of the caps must have fell off at some point then. :excited can't wait to get home and block it off.
probably,
there should be two pipes, one linking 1 and 4, the other linking 2 and 3.
not sure how important it is to link this way.. but it might be.
mine have got little red rubber caps held on with spring slips but i have got a set of the pipes on the other engine so will swap em over i think.
