Compression test/cylinder pressures.
Posted: Fri Aug 29, 2008 6:09 pm
Since I suspect I've managed to pop the head gasket trying to keep up with CBR6RR's and ZX6s round cadwell a few weeks back, I've borrowed a compression tester from a mate.
Manual says it ought to be 99-156psi. I've got:
Cylinder 1: 170psi
Cylinder 2: 140psi
Cylinder 3: 120psi
Cylinder 4: 190psi
A little bit random
Engine's coming out and getting a new head gasket anyway, but I'm surprised by the two high values.
Comments?
Test was done with the coils disconnected, all plugs out, throttle held wide open, engine cold - I've read that it should be done with the engine warm, but that was on a car site. Seems bloody difficult on a bike cos I'd have to warm it up then get the tank and airbox off.
Cylinder 1: 170psi
Cylinder 2: 140psi
Cylinder 3: 120psi
Cylinder 4: 190psi
A little bit random
Comments?
