Scott!! bit of a prob mate!
:smt012
i was packaging them up for you, and ive noticed the right hand hanger and the brake lever has a slight bend in them shocking
I never noticed when they where on the frame, as ive never riden the bike. Im sorry bout that mate, and ive just noticed you have paypalled the money over too.
I mean they work fine, and you could probs straighten them out or use them as is.
If you want me to send your money back thru thats understandable. i should of looked more carefully.
here is a picture to show you, see hanger on right hand side, just where the peg go's thru?
Re: Scott!! bit of a prob mate!
I can bend it out mate, no worrie, if you didn't notice it on the bike then it cant be that major.
Jake, there is another prob, the bolts do not fit, neither does the gear linkage. How did you have yours set up?
the mounting bolts?
they had to be drilled out because they where rounded off by previous owner. what part of the bolts dont fit? are the standard ones to short?
if you cant get your linkage rod to fit, then i shall post you one.
There is no way to get the standard linkage to fit. The standard bolts for one aren't long enough with the spacers, the shoulders on the standard bolts don't allow the rearsets to be secured.
Ahh, soz bout that then mate. Altho i did say i would have to drill the bolts out in my first post, i just presumed this to mean they would need new bolts...maybee i was'nt clear enough, my bad.
I have linkages in my spares that will fit, i presumed wrongly that your standard one would be similar.
up to you mate, if you want a linkage, i shall post you one, or you can post them back to us for a refund and i will put them back in my spares box, no problem
Let me sleep on it mate. I'll have a look at what I can do with them and what bolts I've got etc. I might be tempted to buy a new set, as they are a fantastic bit of kit!
