Water Pump?? H Model
zxr
Post by zxr »
Hi to all :smt006
I have just bought a F plate zxr400 H.
Having rode it i camehome and found the water was boiling. Steam rising from the reservoir.
Then noticed water running down the side of the water pump vsad
I hope from reading other threads and the manual on this site that it is the water pump.
I am driving/riding about 2 hours to get a new Pump from a breakers later today.
The pump i have found is also from a newer model. From speaking to various breakers today i am correct in thinking all the water pumps fit up to 2003?
I really would apprieciate some HELP as i want/need the bike ready for saturday..
Thanks.
Re: Water Pump?? H Model
all water pumps are interchangeable ..
where is it leaking from ? it may be the (steel) pipe from top of the pump that has corroded, or the o-ring that seals the pipe to the pump, or just the hose that connects it to the housing on the block ?
zxr
Post by zxr »
I think it is coming from the hole on the side of the water pump. As i couldnt feel or see any water at the top of the back of the pump(if that makes sense).
I want to get the bike sorted for friday so i can do a track day on saturday.
Just thought on the off chance someone may now of any common/obvious faults with the pumps.
i am tempted to go and buy a pump from a breakers later today although it is a bit of a drive/ride.
what hole on the side of the water pump ?
zxr
Post by zxr »
Sorry when i say hole i mean(the passage. Page 3-7 in the manual on the cooling section):
Water Pump Inspection
.Check the drainage outlet passage at the bottom of the
water pump body for coolant leaks.
* If the mechanical seal is damaged, the coolant leaks
through the seal and drains through the passage.
Replace the water pump unit
Although having only owned the bike for a couple of weeks i dont know :smt017 ... if there is any common faults or easier fixes. I may also buy th metal hose from the top of the pump tommorow aswell if the breakers have one.. Anything as long as the bike is sorted for Saturday at a sensible cost.
