A little worried. Alarming strained noise when pulling away.
- Vard66
When I pull away from standstill, she seems to have a tendancy to make a bit of a grinding, struggling noise. I can't think how to describe it better without being able to listen to it and then immediately post. Sound like anything fairly common, or even better, something that I shouldn't be worried about at all?
rover220
- My Bike: zx7r p6
Re: A little worried. Alarming strained noise when pulling away.
sounds pretty terminal.
ill take the bike off your hands though!!
Sounds like a shot wheel bearing to me. Get each end of the bike in the air and give the wheel a turn, see how it sounds.
or a fecked chain/sprocketsRedexRobB wrote:Sounds like a shot wheel bearing to me. Get each end of the bike in the air and give the wheel a turn, see how it sounds.
or dragging brakes
or a shagged clutch
or a wobbly gearbox sprocket
or a small rodent trapped in the swingarm
- Vard66
ROFL.zimm wrote:or a small rodent trapped in the swingarm
I'll check out all the above points. Thanks chaps.
Mind you, I would hope Elliot's had checked all the above points when they serviced her, so hmm.
