Problem already.
Brett
My Bike: zxr 400 h1
Problem already.
Post by Brett »
As I'm sure you all know I got a gsxr400. Just come in from riding it and noticed oil has been coming out of the right hand side of the head. Not huge amounts, but enough to go onto the fairing. The bike is running very well. Can I tighten the head to stop it leaking?
Action is the antidote to despair.
Brett
My Bike: zxr 400 h1
Re: Problem already.
Post by Brett »
Sorry, left hand side.
i would be more inclined to do the head gasket before it goes and does more damage.
most likely the cam cover gasket mate.
Brett
My Bike: zxr 400 h1
Post by Brett »
What more damage could it do?
well if its the cam cover then the engine will be getting low on oil if its losing it, if its the head gasket it could warp the head.
rover220
My Bike: zx7r p6
Post by rover220 »
masterofinsanity wrote:well if its the cam cover then the engine will be getting low on oil if its losing it, if its the head gasket it could warp the head.
an oil leak warp the head? are you sure?
no i meant if the head gasket blows.
rover220
My Bike: zx7r p6
Post by rover220 »
masterofinsanity wrote:no i meant if the head gasket blows.
if its leaking from the head/block join which is unlikely then the gasket needs replacing anyway. wont warp the head if its not overheating.
ok maybe i'm looking at extreme cases?
rover220
My Bike: zx7r p6
Post by rover220 »
masterofinsanity wrote:ok maybe i'm looking at extreme cases?
maybe, maybe not.
im not sure how the head looks on one of these so dont know where the oil feed runs on them. could have overheated in the past and warped the head though but id go with zimm (cam cover)
Brett
My Bike: zxr 400 h1
Post by Brett »
It does seem to get very hot, although the gauge doesn't reflect this. The exhaust stays too hot to touch for about half an hour after riding.
yes because exhaust temp is a good reflection of coolent temp... :smt017
deviant
Post by deviant »
are gixxer 4's water cooled? or are they oil cooled like the 750s/1100s of that era?
anyway. my money's on the rocker cover, purely because my ZXR's been leaking from there. I took it off last night and supplemented the rubber seal with a bead of instant gasket before torquing it back down. hopefully that will have sorted it.
post a pic up of where its leaking from.
