air filter box h model
dickie210
Post by dickie210 »
hi on me air box under the tank there is a small pipe that looks like it should have a small rubber hose on it, what is this and where should it go without it its just sucking air into the carbs iam not talking about the one on top that goes to the engine. its on the bottom of the box near the carbs cheers
Re: air filter box h model
its just a drain pipe i think, there was probs a hose that went to the belly pan at one point. i would'nt worry about it
ive never noticed one on my h airboxes tho..
yeh, its a drain pipe, doesnt go anywhere, normally has a bit of tube on it about 2 foot long that's got a bung in the end.
zimm wrote:yeh, its a drain pipe, doesnt go anywhere, normally has a bit of tube on it about 2 foot long that's got a bung in the end.
correctomundo and i'm missing one off mine, will get one 1 day.
zxr_oli
My Bike: Daytona 675
Post by zxr_oli »
If i'm thinking about the same pipe, mine connects to a gold nipple type (around 1cm wide) on the engine.
