Hello! I know this is my first post and it might sound suspicious.
Me and my girlfriend are on a track event vacation and she took the wrong key with her for her ZXR 400 bike.
I wonder if someone here please can help me out and point to which cables on the ignition wire loom that I should hook up to what.
I can do the job, I just don't know what connects to what and I rather not make a mess of it all. I can take a guess that 5 of the wires should hook up to eachother and the red cable (plus to battery) should be the decider if the bike turns on. I've bought a switch already to set things up.
Appreciate any help!
There are 2 plus cables that goes to the battery plus. And there is one cable that is semi-ground with around 6 volts when connected to the two plus cables going to the battery.
The rest are smaller cables that I guess goes to P (parking) and other stuff such as lights.
I can get the ignition to go on, but upon pressing the starter the starter runs but the bike won't fire up. And I bet that has to do with the spark plugs not getting any juice from the batteri.
No key - remove ignition
- deviant
- My Bike: ZXR400 L3
Re: No key - remove ignition
you can find the wiring diagram in pdf format from the link below -
(under 'electrical' for the appropriate model)
You can work out which colours of wire you need to join together from that.
some here too on the forum viewtopic.php?f=55&t=5852&p=45589#p45589
