Questions about bearings
gt185
My Bike: ZXR400H2
Post by gt185 »
My H2 just failed it's mot for a knackered rear wheel bearing, so I ordered
replacements and set out to have a go.
First question - What's the best way to get the bearing out? A long flat blade
screwdriver perhaps? There looks to be just enough of an inner edge to catch,
but wondered what tool you guys would use.
Second question - on the disk side, there's a thick rubber washer that sits
on the outside of the bearing. Again, what's the best way you guys have
found to get it out, without causing too much damage.
Cheers.
Re: Questions about bearings
you missed this thread then? viewtopic.php?style=17&f=55&t=4688
yeah you can use a screwdriver or a even better some bearing pullers about £38 a set but worth it. the rubber rings are oilseals 35x52x7 i think, have a look on them for a size, you can rip them out but you will need to replace them.
gt185
My Bike: ZXR400H2
Post by gt185 »
I knew there was play in the bearings, so bought replacements before the thread appeared,
ah well, not to worry.
Bearing pullers - sounds like a good idea.
Wasn't sure if the oil seal could be removed carefully, and hence not need replacing.
where dya get the bearings from ? are they oem or replacements just check what they send you cos they may be rubber sealed anyway so it may not matter bout the oilseals.
gt185
My Bike: ZXR400H2
Post by gt185 »
From WE Moto.
gt185
My Bike: ZXR400H2
Post by gt185 »
Sorry, they're replacements, not OEM.
The rubber I'm talking about is on the disk side and basically looks like a large
washer that sits in the hub on the outside of the bearing, in a groove.
have a look on the microfiche mate should be a rubber seal either side of the wheel.
gt185
My Bike: ZXR400H2
Post by gt185 »
Had a look at the fiche earlier, and did see the seal on both sides, but wondered
why there was only one on mine. Maybe explains why the sprocket side bearing
has gone before the disk side........
the big seal can be prised out with a flat blade screwdriver without damaging it, use the same one to twat the bearings out of the wheel.
gt185
My Bike: ZXR400H2
Post by gt185 »
Cheers all. I'll have to order one for the sprocket side, so might just go ahead
and order the disk side one too.
like i said mate pop it out and let me know the size cos i have oilseals at work, may have the size you need.
gt185
My Bike: ZXR400H2
Post by gt185 »
Cheers, I'll do that. I mid-read the other thread, and thought it was all bearings
that were being talked about, not seals as well. Will let you know. thanks.
