Hot starting problem to the extreme!
zxr_oli
My Bike: Daytona 675
Post by zxr_oli »
My hot starting problem has now gone to the extreme.
Say if i start it up and i let of the choke to early/much so it stalls, just from those 30 secs of running will be enough to cause it not to start again without bump starting it (good job my driveway is on a slope :p), but even then it take a bit to get it going.
It will spin over a few times, then act like the battery is flat turning over very slowely and eventually not atall. :smt017
Can anyone think of why it must do this after such a short time?
Everything else is fine (apart from my downpipes :smt013 ), i can't see why it would do this.
Re: Hot starting problem to the extreme!
Might be worth doing a compression test.
rover220
My Bike: zx7r p6
Post by rover220 »
does it turn over really quickly like theres a lack of compression?
zxr_oli
Post by zxr_oli »
rover220 wrote:does it turn over really quickly like theres a lack of compression?
Nope, turns over normally.
It's literally a few turns and then it struggles to any more, asif the battery was flat.
Once running its fine, bogs down a little under 4k, but then i do have a hole in my pipes so i'm assuming that is causing that.
Do you think i could have rediculously high compression?
rover220
My Bike: zx7r p6
Post by rover220 »
its unlikely youve got rediculously high compression. sounds more like a weak spark.
zxr_oli
Post by zxr_oli »
I could understand how a weak spart would stop it from starting, and the fact that the hold in my pipes would make it run lean so therefore more likely to foul the plugs. But i can't understand why it doesn't turn over (well) :smt017
How old is the battery? Cant think of anything else other than that,
sounds like the battery's shagged!
zxr_oli
Post by zxr_oli »
Battery is only a couple of months old :smt009
Will check the voltage and acid levels when i get chance, just strange how it works perfect when cold or once running.
carsounds_dan
Post by carsounds_dan »
have you had your engine casings off?
I know when mine had been off the left hand one that has the intermediate gear for the starter was on too tight meaning it would get too hot, expand and stop the starter from turning... worth a check, either that or take out and re-set your camchain tensioner, could have over tightened the camchain somehow.
dan
...i know, it's great :D
zxr_oli
Post by zxr_oli »
carsounds_dan wrote:have you had your engine casings off?
dan
Havn't touched it, but i will give those a check :)
anakin40
My Bike: zxr400 l4
Post by anakin40 »
hi, know this is an old post but wondered if you resolved the issue? i have exactly the same problem, and the engine casing gets really hot...
anakin40
My Bike: zxr400 l4
Post by anakin40 »
turns out mine had a magnet break off the housing in the starter motor!
