Aiming for 75hp
AdamZXR
My Bike: ZXR 400 L8
Aiming for 75hp
Post by AdamZXR »
im trying to get my ZXR upto 75hp was wandering where can i get all this from
:- ENGINE= Balanced crank, rods and pistons with small fly wheel
. 0.5mm oversized pistons. RMKD prepared head.(skimmed, gas flowed and valves reprofiled)
Factory copyed ram air box.
33mm flat slide carbs.
Superchiped CDI (rev limit raised)
cheers adam
rover220
My Bike: zx7r p6
Re: Aiming for 75hp
Post by rover220 »
theres a ram air box on ebay.
for the rest id get a shot engine and use the crank ect from that, then when its all ready itll be a simple engine swap.
Re: Aiming for 75hp
Im sure the racers can tell you where to get the engine tuning done. I guess a blueprint would be a good start, polished ports and adjustable cams.
Hodson Engineering can do alot of that i think, but they are in Kent so a bit far from you!
Ballsout Racing
Re: Aiming for 75hp
Post by Ballsout Racing »
AdamZXR wrote:RMKD prepared head.(skimmed, gas flowed and valves reprofiled)
If you want an RMKD head, then go to RMKD, he'll probably do it all for you, I haven't used him but he's certanily produced some fast bikes.
AdamZXR wrote::- ENGINE= Balanced crank, rods and pistons with small fly wheel. 0.5mm oversized pistons.
Otherwise you can get it all done at Dynotech in Basingstoke.01256 881711
AdamZXR wrote:Factory copyed ram air box.
BB Plastics, http://www.bbplastics.co.uk/kawasaki/airbox_zxr400.htm
AdamZXR wrote:33mm flat slide carbs.
Ebay, or keep an eye on the racing forums. But TBH, not worth the expense IMO, they'll be £350+ then plenty of Dyno time to get them set up. Can give a good power boost on a standard engine, but very little on a well tuned engine.
AdamZXR wrote:Superchiped CDI (rev limit raised)
Not sure, but a chap called Anthony Hayward used to do them, not sure where or what he's up to now, Simon Lowes I think knows, http://zxrworld.co.uk/zxr400oc/memberli ... file&u=215
Greville
Ballsout Racing
Re: Aiming for 75hp
Here's acheap way of getting some of it :smt002 : http://www.400greybike.co.uk/forum/topi ... C_ID=70004
You don't often get oportunities like that! BTW, I don't know the bike or seller so don't know if it's any good, but the piston and rings alone cost £200 new and the SP cams cost near £500, so the engine alone at £500 is worth looking at :smt001 If I was still racing I'd be there like a shot :smt002
Re: Aiming for 75hp
That is good isnt it. Alot of the work probably already done too!
Re: Aiming for 75hp
yep, and even better still, he states you can go and run it up in the bike first.
im tempted, just a bit far aways
AdamZXR
My Bike: ZXR 400 L8
Re: Aiming for 75hp
Post by AdamZXR »
thanks for getting back guys i owe ya! usefull stuff. kents a bit far away yeah. but there are a couple bike tuners/dynos up in exeter i found out today and maybe one down in redruth in cornwall..... but id probably go exeter ill have to look on ebay and cheers for the links :)
BANJO
My Bike: ZX4R NINJA
Re: Aiming for 75hp
Post by BANJO »
hello adam mate hows u. Don't know if u've tryed this bloke he's well good
if u come up to exeter pop in and say hello
there is a dyno down in plymouth mate
dean
AdamZXR
My Bike: ZXR 400 L8
Re: Aiming for 75hp
Post by AdamZXR »
ooh that seems pretty good. dyno in plymouth would be alright. yeah that'd be great. we still got to go for that cruise sometime :smt003. been sending emails and calling up places. soon she will be a monster :smt002 has anyone else noticed the amount of ZXR's on ebay.......
Re: Aiming for 75hp
really?
well i never
