K&N with no snorkal and aftermarket Can
Posted: Mon Mar 24, 2008 1:45 am
by MillaMeter
Hi,
Straight to the point here, basically I have a K&N air filter fitted with no snorkal and a after market no baffle s/steel end can. What I need to know is what jet sizes to use and what needle settings?
Richard
Re: K&N with no snorkal and aftermarket Can
Posted: Mon Mar 24, 2008 7:40 am
by rover220
i have a k and n with the snorkel removed and have 105 main jets.
Posted: Mon Mar 24, 2008 12:44 pm
by MillaMeter
rover220 wrote:i have a k and n with the snorkel removed and have 105 main jets.
Thx for reply,
was that from a Dynojet kit by any chance?
Thx
Rich
Posted: Sun May 04, 2008 1:12 am
by zimm
#105 keihin jets , equivalent dynojet ones would be #100/#102 for that setup
Posted: Sun May 04, 2008 8:36 am
by rover220
zimm wrote:#105 keihin jets , equivalent dynojet ones would be #100/#102 for that setup
cheers dude
Posted: Sun May 04, 2008 3:07 pm
by zimm
you've got dynojet needles too Mike, stock needles may require different jets.
Posted: Mon Jul 14, 2008 2:31 pm
by thermal
why is it when using a KnN, you need to remove the snorkel?
Posted: Mon Jul 14, 2008 2:55 pm
by zimm
general consensus is that the KnN blocks the snorkel partly and runs richer than stock with it fitted.
sounds better without it too.
Posted: Wed Jul 16, 2008 11:48 am
by thermal
in which case is it worth removing the snorkel even when using the standard air filter? what is the purpose of the snorkel anyway?
Posted: Wed Jul 16, 2008 12:40 pm
by zimm
the OE filter is different to the KnN, it doesnt block the end of the snorkel.
you can remove it, but you'll need to re-jet, and maybe play with needles.
its to smooth the airflow to help prevent flatspots, and to quieten the induction noise.
Posted: Sun Jul 20, 2008 11:37 am
by thermal
i dont want it to be quiet. if i put a knn on, will it still need re-jetting?
