Page 1 of 2
sump types?
Posted: Fri Mar 14, 2008 7:09 pm
by carsounds_dan
sump types?
My new engine i've got doesn't have any spaces for an oil cooler to be bolted on... is this a standard zxr thing or a thing racers do or what type of zxr's have them? I was thinking maybe it's a sump off a zx4 or a different kawasaki model.
what do you think?
dan
Re: sump types?
Posted: Fri Mar 14, 2008 7:22 pm
by rover220
some didnt come with an oil cooler, just had a bigger radiator instead.
Re: sump types?
Posted: Fri Mar 14, 2008 7:44 pm
by Jamz
rover220 wrote:some didnt come with an oil cooler, just had a bigger radiator instead.
Are you sure?
I'd have thought unless it's an air cooled bike it's got to have an oil radiator somewhere? :smt017
As far as I remember the sump on all the L models is the same, but the H was slightly different.
Re: sump types?
Posted: Fri Mar 14, 2008 9:41 pm
by jake
i aint checked my new L yet, but on my H, the oil cooler bolts to the underside of the rad..if that helps
Re: sump types?
Posted: Fri Mar 14, 2008 11:07 pm
by Ballsout Racing
H and L models have different oil coolers.
Re: sump types?
Posted: Fri Mar 14, 2008 11:10 pm
by Ballsout Racing
Never heard that. both H and L have oil coolers. Oil has to be kept within a certain temperature to work efficiently, so that's not to say ZXR400 sold in Siberia will have oil coolers as they would probably be pointless :smt002
Re: sump types?
Posted: Fri Mar 14, 2008 11:16 pm
by Ballsout Racing
Jamz wrote:I'd have thought unless it's an air cooled bike it's got to have an oil radiator somewhere? :smt017
That's a mighty generalization :smt017
It surely depends how efficient the engine is. In fact, I'd have thought air cooled engines are more likely to require an oil cooler to keep the oil temperature within it's operating range as it will lack the efficiency of water cooling :smt017
Re: sump types?
Posted: Sat Mar 15, 2008 3:52 am
all zxr400s had an oil cooler, if anyone wants to prove me wrong go ahead, i have the facts in black and white and there were no variations for imports.
In answer to Dans question it may well be a one off sump or like you say off another kwak, post up a pic please this is interesting.
Re: sump types?
Posted: Sun Mar 16, 2008 12:05 am
must be a beet sump to go with the beet cams :smt005
Re: sump types?
Posted: Sun Mar 16, 2008 6:41 pm
by carsounds_dan
I dunno, i'll get a pic up when I re-build that engine.
dan
Re: sump types?
Posted: Tue Mar 18, 2008 12:10 pm
by deviant
Jamz wrote: I'd have thought unless it's an air cooled bike it's got to have an oil radiator somewhere? :smt017
I believe VFR/RVF 400's don't have oil coolers. they have two water radiators instead.
Our GPZ500 only has a water radiator.
Re: sump types?
Posted: Tue Mar 18, 2008 10:58 pm
by Jamz
I think the oil in a V4 may run much cooler, because the VFR750's have a tiny oil cooler above the rad that's about an inch tall. Actually even the water radiator was about half the size of a ZXR400, too!
Re: sump types?
Posted: Wed Mar 19, 2008 7:59 am
by deviant
But if you tuned a VFR750 to give the same bhp/cc as a ZXR (ie about 115-120bhp) then I expect you'd need more cooling.
Re: sump types?
Posted: Wed Mar 19, 2008 9:49 am
by Jamz
deviant wrote:But if you tuned a VFR750 to give the same bhp/cc as a ZXR (ie about 115-120bhp) then I expect you'd need more cooling.
I'm not too sure about the effects of tuning on cooling, but I should imagine that depends what type of tuning you do?
So a rebore shouldn't really need better cooling, but something that raises the revs will?
Re: sump types?
Posted: Wed Mar 19, 2008 11:12 am
by deviant
not really,
you aren't going to make some fantastic increase in the efficiency of the combustion process*, so all you are really doing with almost all forms of tuning is chucking more fuel in to get more power out. With that you will have a proportionate amount of extra heat coming out.
it's a simplification, but it is true to say that a VFR750 is not in anything like as high a state of tune as a ZXR4.
*of the top of my head it's about 30% max for the otto cycle, so for every extra 1kW of power you get out, you'll be chucking out an extra 2kW of heat. Mmm toasty.
