Hi all,
I've got a load of pictures of when I checked my clearances, if anyone knows if there is a site that will host for free, there is 6 pictures in total.
ALSO I have got one more clearance to do, and I can't get the bloody shim, so I was wondering what's better. I can either have the clearance 0.03mm too big or 0.02 too small but can't find the shim I need to find the middle ground. It's an inlet valve if that helps.
dan
									Valve clearances
- carsounds_dan
Valve clearances
...i know, it's great
				rover220
 - My Bike: zx7r p6
Re: Valve clearances
i don't charge people to upload to the gallery mate.carsounds_dan wrote:Hi all,
dan
						- deviant
 - My Bike: ZXR400 L3
Valve clearances from the manual
0.12 - 0.17 (Inlet)
0.16 - 0.21 (Exhaust)
you just need to have it somewhere in that range. It doesn't have to be an exact value. Since the range is 0.05mm then I imagine shims are available in 0.05mm steps, since that ensures you will always be able to select one that puts the valve clearance within range.
									0.12 - 0.17 (Inlet)
- carsounds_dan
I know but I can't find the damn shim that puts it in that lovely middle ground.
pics and a writeup to come
