carb problem fuel leaking
bato
Post by bato »
Hi
I am new on this topic and I am sorry if something write wrong because english is not my lenguage.
I have ZXR400L4 and problem with my bike is hard start engine and when bike working fuel leak from litle yelow pipe from right back side of carbs between 3 and 4 carb.
What can be problem and how I can correct them?
thanks
Re: carb problem fuel leaking
Hi there bato, it sounds like there may be some dirt inside your carbs or the float needles have worn.
Id get them apart to clean them and also check the float needles and replace if necessary.
hope that helps
RobB
bato
Post by bato »
Hi Rob
Thanks for quick answer today I going to predict carbs.
cheers
No problem, let us know how you get on :smt001
hello bato have you read this? viewtopic.php?f=7&t=3391
bato
Post by bato »
Hi
I am finish cleaning carbs.
This bike is 2 weeks by me.Bike stay 2 years and Whe I open carbs there were lots of dirty and oxidation.After cleaning ,fuel dont licking.
Now I have problem something produce sound somewere around valves betwen 4000-6000 rpm.For now I havent time to remove valves cover to verification valves.
Year of made 1994
Model ZX400L04
20120 km
I dont know if somebody something repair.
thanks
Hello again bato, im glad you have the carbs sorted. If the noise coming from there is a tapping sound it may be the valve clearances need doing. Have you taken the bike for a ride? The valves may be noisy because of a lack of oil at the top end where its been standing for a long time.. Let us know how you get on.
RobB
bato
Post by bato »
Hi
I have ride once because litle is cold for drive.Bike working exelent.Lots of power exelent breakings but noise coming with 4000 rpm and finish after 6000 rpm.
cheers
Actually, on second thoughts, does anyone else think it might be the cam chain? I think if the clearances need doing the engine will be noisy through all the revs.
bato
Post by bato »
Hi
Yes you have right .Valves ore something about valves creating nois hole time.I think cam chain is not because sound is like (litle hamer) I thing problem is in the seesaw.
carsounds_dan
Post by carsounds_dan »
Mine would make a little tapping noise between 5500 RPM and 6000 RPM and it was the camchain (came from the top right hand of the engine). I replaced the tensioner aswell. I should think yours is getting to about the right milage for valve clearance checks, but I'd check the camchain and tensioner as-well. The tensioners work out about £75.
cheers
dan
...i know, it's great :D
bato
Post by bato »
Hi
I think problem with soun is finish.
I have change oil and sound disappear.In the old oil I find petrol (result carb licking).
For now soud is OK.I have to testing bike for a some time and then I can create full diagnose of my zxr 400.
Thanks for hints
