Scottoiler
olionel
My Bike: 98' ZXR400
Scottoiler
Post by olionel »
Hello; just confirming....
Looked on scottoiler website, zxr400 wasnt listed on the "Non-standard fittings" guide, so am I right in thinking the universal kit should fit with no problems or any extra bits needed? (L model)
Thanks!
Oli
rover220
My Bike: zx7r p6
Re: Scottoiler
Post by rover220 »
mark 7 universal kit will fit fine, its what ive got on mine.
dead easy to fit, if you need any help shout me!
Re: Scottoiler
Yeah easy as mate, just in case you need to know the vaccum point is wither one of the two pipes that connect cylinder 1 and 4, or 2 and 3. Just cut the pipe in half and stick in the white T piece and then connect the thin black black tubing to it via the connector. Then rout the black tubing to wherever you have the reservoir located. I found it will actually fit underneath the riders seat at a squeeze :smt001
rover220
My Bike: zx7r p6
Re: Scottoiler
Post by rover220 »
ill have to get some pics of my setup.
my reservoir is bolted to the rear subframe.
olionel
My Bike: 98' ZXR400
Re: Scottoiler
Post by olionel »
thanks a lot folks, I shalst buy one at once... and fit it... :smt001
Thanks!
Oli
deviant
Re: Scottoiler
Post by deviant »
I've just bought one from this chap
http://myworld.ebay.co.uk/rjr9090
Turned up the next day.
Scottoiler have a ZXR specific installation guide which you can download here
http://www.scottoiler.com/support_insta ... guides.asp
just need to finish the workbench I'm building (currently sat smack in the middle of the garage, will live nicely against the wall when its done) so I've got space to work on the bike.
