Exhaust Springs
crushedlizard
My Bike: ZXR400 L2
Exhaust Springs
Post by crushedlizard »
My exhaust downpipe has lost a spring on one of the pipes so sounds like a little v-twin at the moment. Any idea where I can get some new springs ie. what size they are etc?
I did a quick search on the forum but couldn't find threads.
(I'm assuming they use springs and not bolts!? If not, man am I gonna look stupid...
Sorry, if there's a really obvious answer to this.
Josh
Re: Exhaust Springs
they are bolted on mate unless you have a race system fitted then they may have springs somewhere along the pipe.
rover220
My Bike: zx7r p6
Re: Exhaust Springs
Post by rover220 »
all the springs off my micron system are missing.....any ideas where to get them from?
crushedlizard
My Bike: ZXR400 L2
Re: Exhaust Springs
masterofinsanity wrote:they are bolted on mate unless you have a race system fitted then they may have springs somewhere along the pipe.
bugger. I thought they were bolts but saw loads of pictures of exhausts with springs. You're right though, they were all race pipes and I didn't think any different.
Cheers, at least I know what I'm looking for now!
Any idea what size they are off the top of your head? If not don't worry, I'll hunt through the manuals.
Thanks again.
Josh
deviant
Re: Exhaust Springs
Post by deviant »
do you mean the bolts holding the downpipes to the engine (which are probably actually nuts on studs) or the bolts holding the can on?
if it's the latter I'll whip one out and measure it when I get home.
The standard downpipes/collector are welded together aren't they?
crushedlizard
My Bike: ZXR400 L2
Re: Exhaust Springs
deviant wrote:do you mean the bolts holding the downpipes to the engine (which are probably actually nuts on studs) or the bolts holding the can on?
Yeah sorry, I wasn't very clear. I mean the bolts/nuts that hold the 4 individual pipes to the engine. One of them has come loose somehow.
deviant
Re: Exhaust Springs
Post by deviant »
well I'm afraid my level of motivation doesn't extend to trying to get at those to measure them. Sure someone with a bike in bits will be able to tell you.
I'd hazard a guess that they are M6 or M8 nuts though.
crushedlizard
My Bike: ZXR400 L2
Re: Exhaust Springs
deviant wrote:well I'm afraid my level of motivation doesn't extend to trying to get at those to measure them. Sure someone with a bike in bits will be able to tell you.
Haha, I don't blame you - I've failed to take a proper look and it's my bike that's in need! :smt003
I've got a few days off so will finally have a chance to take a proper look.
Thanks anyway.
carsounds_dan
Re: Exhaust Springs
Post by carsounds_dan »
theyre M6, i put new stainless ones in mine but they seemed a bit shitty and couldnt get the nuts to hold on tight enough properly so changed them with 25mm M6 bolts, they went in fine and held in good, theyre stainless as well.
cheers
dan
...i know, it's great :D
crushedlizard
My Bike: ZXR400 L2
Re: Exhaust Springs
carsounds_dan wrote:theyre M6, i put new stainless ones in mine but they seemed a bit shitty and couldnt get the nuts to hold on tight enough properly so changed them with 25mm M6 bolts, they went in fine and held in good, theyre stainless as well.
cheers
dan
Cool, cheers mate. I'll grab a few and try them out. Else, I'll have to stop being a lazy giraffe and take one of the others out!
The weather is dry, the sun is out and my ZXR is staring at me through my window. I need to get out there!
