Page 1 of 2
micron exhaust
Posted: Thu Jan 10, 2008 8:01 am
by kwackkev22
hey chaps
does any one know if micron make another end can to fit there pipework for the zxr400 ive got the stainless round one on my bike and iam not to happy with the sound its to quite for me and just looks like its a standard fit. i want an oval one with out spending to much just wonderd if any of the bigger qwaks had the same size pipe so i can keep an eye on ebay for one
thanks
kev
Re: micron exhaust
Posted: Thu Jan 10, 2008 10:01 am
by tobomoto
i was using a mates round carbon one for a while. it was from a zxr 750. all you need to look for is a 65mm inlet but they dont come cheap, even on ebay. i got a stainless oval race stubby from fuel. cost 145 quid delivered but it fitted perfect and sounds like a tank.
Re: micron exhaust
Posted: Thu Jan 10, 2008 10:19 am
by jake
The microns have a baffle in the link pipe, which will more than likelly make it quiet aswell as strangle a bit of extra performance. I have a micron that was on mine, and it boomed, right on the track limit noise wise. Altho, im not 100% sure how you get the baffle out unfortunatley.You would have to put some bigger main jets in there tho
Re: micron exhaust
Posted: Thu Jan 10, 2008 1:41 pm
what's your inlet diameter on the micron mate? 62mm??
Re: micron exhaust
Posted: Thu Jan 10, 2008 2:00 pm
by Jamz
If I remember correctly, the Micron on my ZXR750 was a hell of a lot bigger pretty much everywhere than the Micron on my ZXR400...
I've never really understood myself why you can't shove the can from anything onto any other bike - as long as it's set up properly it should be ok? Although if the diamter and length is different it WILL affect performance one way or the other...
Re: micron exhaust
Posted: Mon Jan 14, 2008 1:13 am
by kwackkev22
yeah mate 62 or 67mm iam just gonner keep an eye out on ebay thought about goin back to the standard system the choice of cans is much wider. i just miss the roar of my g force end can it sounded sweet. now it just sounds like a standard touring bike
thanks for your in put chaps
Re: micron exhaust
Posted: Mon Jan 14, 2008 9:56 am
by rene
stubby your micron if you really want ear bleeding loud
Re: micron exhaust
Posted: Mon Jan 14, 2008 11:39 pm
by nick_c
I managed to get a set of micron pipes but without an end can.
Finally got a can from AMS which is from a ZXR750, looked at fitting the pipes and can tonight but the can looks much bigger than the existing and the existing one is close to the swing arm.
Tobomoto if you read this you said you had a micron 750 can on your 400 for a while, did it fit ok or did you have to modify anything?
The guy at AMS said it was the same can for the 750 and the 400, I now see from reading the above posts that this is not true. Also the can was supposedly only used to try an engine, but it arrived scratched, slightly squashed with a dent, so not at all impressed with AMS, which is a shame as I was going to get their body kit.
Now I am sure that AMS have not told the truth I am seeking advice to see if the 750 can will fit straight onto the 400?
Any help will be most apreciated.
Thank you, Nick.
Re: micron exhaust
Posted: Tue Jan 15, 2008 12:45 am
by nick_c
If anyone has the time could they measure the diameter/circumference of a micron 400 race can and also the length of the main body.
Thank you, Nick.
Re: micron exhaust
Posted: Tue Jan 15, 2008 10:01 am
by rene
iirc micron used the same can on loads of diffrenet systems.
Re: micron exhaust
Posted: Tue Jan 15, 2008 10:03 am
nick_c wrote:I managed to get a set of micron pipes but without an end can.
Thank you, Nick.
tell them you're not happy mate, AMS give discount to official members of the zxr400oc i'm sure they would want to know if they haven't fulfilled your expectations.
Re: micron exhaust
Posted: Tue Jan 15, 2008 9:27 pm
by tobomoto
hi the can was a round carbon road legal one. i only really had it for the mot but it turned into 7 months. fitted perfectly no mods required but it was quite long. it was nearly level with the numberplate. i got my own micron road legal round stainless now and again it fitted no probs. i bought it as a universal can so it should be ok on any 65mm inlet pipe. i dunno if it affected performance as somone mentioned earlier as i had to give it handfuls to sound any good! waaaaaaaaaay too quiet.
Re: micron exhaust
Posted: Tue Jan 15, 2008 9:36 pm
by nick_c
Cheers tobomoto.
I did not want to start putting on the new micron pipe work and find the can did not fit.
Thanks again, Nick.
I am so glad I found this site.
Re: micron exhaust
Posted: Mon Feb 04, 2008 3:06 am
by kwackkev22
hi chaps ive managed to get a nice carbon end can for the zxr it will go stright on to the micron pipe work just not sure how it will run its off a cbr600 with a 65mm slip on clamp will let you lot know how it runs. thats if i get it the guys only got -2 feedback on fleebay lol
take care chaps
kev
Re: micron exhaust
Posted: Mon Feb 18, 2008 9:53 pm
by kwackkev22
hey chaps ive got a micron race can found it on ebay payed 65 quid for it and it sounds well cool same fit as the stainless one as well 65mm and bolted stright to the can hanger just got to polish the NOT FOR ROAD USE out now
thanks kev
