the front sprocket on my bike is knackered, does any one know where i can get one from? and is the sprocket on the H1 engine the same as the L engines?
Thanks,
James
Front Sprocket
Re: Front Sprocket
I beleieve they are the same. But you should change the chain and sprockets as a set and not one piece at a time. Best bet is probably Cradley's or maybe somewhere online.
rover220
- My Bike: zx7r p6
- zxr_oli
- My Bike: Daytona 675
Re: Front Sprocket
Yup, sprockets are the same
- jake
Re: Front Sprocket
where can ya get the retainer thing, that slips over the front sprocket? do they supply them with the new front sprockets?
took my engine out last week, and the sprocket just fell on the floor! the retainers teeth have worn thru..
Re: Front Sprocket
don't belive they do mate, i'll have a look in my toolbox tommorrow, think i have one.
- carsounds_dan
Re: Front Sprocket
i only replaced my front sprocket the other week, came to a tenner, it's not quack but hey ho.
the bloke before had changed the chain and rear sprocket but not the front... what a plank. the retainer is seporate, i got another one stamped out of high tensile steel for the future if i ever needed one.
cheers
dan
cheers
dan
...i know, it's great
- jake
Re: Front Sprocket
thanks Baz.
Where did you get yr one from Dan?
- carsounds_dan
Re: Front Sprocket
only the local bike shop,
called "the motorcycle centre" theyre based in blindley heath but also have a shop in felbridge.
cheers
dan
cheers
dan
Re: Front Sprocket
i do have one which i believe is off the zxr400 if you want it pm me your address.masterofinsanity wrote:don't belive they do mate, i'll have a look in my toolbox tommorrow, think i have one.
