5000-6000rpm rattle
bl4nk
5000-6000rpm rattle
Post by bl4nk »
Hey guys,
Ive noticed that my bike has a quite destintive rattle when it gets to 5000-6000rpm. Its not overwelming but i can here it over my race can. Its a sort of metal on metal sound. My bike has a clutch rattle at idle anyway, and sounds sweet after 7000rpm, but its just this little problem area.
I have a road near me where there are 3 humpback bridges, so i am keen on a jump or two, so i could have bent something? or does this sound like a mechanical problem.
Ben
Re: 5000-6000rpm rattle
first things first does it go away when you pull the clutch lever in?
bl4nk
Post by bl4nk »
no it doesnt
spaz
My Bike: ZXR400L2 with K-RASH
Post by spaz »
if it sounds like tiny bells are going off in your engine, or like a chain is being dragged behind you while moving, then it's the camchain tensioner and/or camchain.
I also experienced a bizzar non-bell-like rattle about 1000kilometers before the bells turned on in the same rpm range as you describe; I thought it was a header pipe leak (header washers didn't help but a camchain did (still waiting for the tensioner from japan)). My bike had done about 41,000kilometers when all this started happening.
