carb heaters
Posted: Thu Nov 22, 2007 7:09 pm
by rover220
can anyone tell me if these carbs (in the pic) are the heated variety
Re: carb heaters
Posted: Thu Nov 22, 2007 7:13 pm
in short, yes
Re: carb heaters
Posted: Thu Nov 22, 2007 7:14 pm
by rover220
RobB wrote:in short, yes
lol, cheers.
i presume the brown looking cylinder thing is the water feed?
Re: carb heaters
Posted: Thu Nov 22, 2007 7:17 pm
yeah thats right, theres a pipe which routes from the left hand side of the radiator and down underneath the genny cover. Around there, there should be a take off for a pipe which routes upto that brown bottle type thing
Re: carb heaters
Posted: Thu Nov 22, 2007 7:18 pm
by rover220
RobB wrote:yeah thats right, theres a pipe which routes from the left hand side of the radiator and down underneath the genny cover. Around there, there should be a take off for a pipe which routes upto that brown bottle type thing
nice one mate
Re: carb heaters
Posted: Fri Nov 23, 2007 8:49 am
ok, so what is the brown bottle type thing for?
Re: carb heaters
Posted: Fri Nov 23, 2007 9:08 am
no idea Baz, i assume it could either be a filter or just a way of telling to see if the system is full as it goes the colour of the coolant you put in.
Re: carb heaters
Posted: Fri Nov 23, 2007 9:36 am
by rene
i always thought its a filter, mine was green tho
Re: carb heaters
Posted: Fri Nov 23, 2007 9:38 am
could it be a pump to prime the pipes??
Re: carb heaters
Posted: Fri Nov 23, 2007 9:40 am
might be, not sure how that would work tho.
Re: carb heaters
Posted: Fri Nov 23, 2007 9:43 am
its only soft plastic aint it? i think i've got one at home i'll have a look over the weekend.
Re: carb heaters
Posted: Fri Nov 23, 2007 9:46 am
by rene
nope mine was hard plastic, nout you could do with it. My CRM heater dosent have one tho
Re: carb heaters
Posted: Fri Nov 23, 2007 9:50 am
scrap what i said it goes round the other way! The big pipe round the genny cover has a smaller one that routes upto the other side of the carbs, then then a pipe comes off from the bottle type thingy which then plugs into the back of the engine underneath one of the inlets. This picture shows it nicely, underneath inlet number 1 with the pin for the thermostat or whatever it is just in front of it
Re: carb heaters
Posted: Sun Nov 25, 2007 7:56 pm
by mongo
the plastic cylinder houses a filter. You should always open this up and take the filter out and give it a good clean when changing the coolant.
The colour of the cylinder will depend upon what colour your coolant is
